Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Fossil Q Marshal Gen 2 Motherboard Replacement
Qué necesitas
  1. Fossil Q Marshal Gen 2 Motherboard Replacement, Back Cover: paso 1, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Squeeze retaining pins together to release chain from watch body. This can be done by hand or with tweezers.
    • Remove chain from opposing side of watch body.
    Pregunta a FixBot
  2. Fossil Q Marshal Gen 2 Motherboard Replacement: paso 2, imagen 1 de 1
    • Use tweezers to grip the notches on the back cover, then unscrew the back cover (counter-clockwise) from the watch housing.
    • There is an actual tool made to remove this back cover, using the right tool may save you from scratching the back of watch with tweezers. The backcover tool can be purchased online, a local jeweler may also be willing to remove it for you.
    Pregunta a FixBot
  3. Fossil Q Marshal Gen 2 Motherboard Replacement: paso 3, imagen 1 de 2 Fossil Q Marshal Gen 2 Motherboard Replacement: paso 3, imagen 2 de 2
    • Utilize tweezers or a spudger or your fingers to pull the black wire connector from the motherboard.
    • Utilize a spudger to pull the orange connector off of the motherboard.
    Pregunta a FixBot
  4. Fossil Q Marshal Gen 2 Motherboard Replacement: paso 4, imagen 1 de 1
    • Utilize tweezers to pull the white battery connector from the motherboard.
    Pregunta a FixBot
  5. Fossil Q Marshal Gen 2 Motherboard Replacement: paso 5, imagen 1 de 3 Fossil Q Marshal Gen 2 Motherboard Replacement: paso 5, imagen 2 de 3 Fossil Q Marshal Gen 2 Motherboard Replacement: paso 5, imagen 3 de 3
    • The internal electronics can now be pulled out of the watch as one unit leaving the screen remaining in the watch housing.
    • Taking the flat end of the spudger, pry it up.
    Pregunta a FixBot
  6. Fossil Q Marshal Gen 2 Motherboard Replacement, Battery: paso 6, imagen 1 de 1
    • The battery is secured to the back of the motherboard utilizing a sticky pad. Gently separate the battery from the board while making sure not to put too much stress on the board. This is best done at the location shown.
    Pregunta a FixBot
  7. Fossil Q Marshal Gen 2 Motherboard Replacement: paso 7, imagen 1 de 2 Fossil Q Marshal Gen 2 Motherboard Replacement: paso 7, imagen 2 de 2
    • Remove battery from plastic housing.
    • Slip wires through large slot in plastic housing to completely remove.
    Pregunta a FixBot
  8. Fossil Q Marshal Gen 2 Motherboard Replacement, Motherboard: paso 8, imagen 1 de 1
    • Using your finger remove the metal hooks from the black electronic housing.
    Pregunta a FixBot
Conclusión
4 personas más completaron esta guía.
Matthew Tucker
Miembro Desde 11/07/17
586 Reputación
3 Guías creadas
Equipo
IUPUI, Team S2-G5, Harley Fall 2017 Miembro de IUPUI, Team S2-G5, Harley Fall 2017
IUPUI-HARLEY-F17S2G5
Miembros de 3
6 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 41
Todo El Tiempo: 3,292
