Saltar al contenido principal
Fossil Q Marshal Gen 2 Battery Replacement
Qué necesitas
  1. Fossil Q Marshal Gen 2 Battery Replacement, Back Cover: paso 1, imagen 1 de 1
    • Squeeze retaining pins together to release chain from watch body. This can be done by hand or with tweezers.
    • Remove chain from opposing side of watch body.
  2. Fossil Q Marshal Gen 2 Battery Replacement: paso 2, imagen 1 de 1
    • Use tweezers to grip the notches on the back cover, then unscrew the back cover (counter-clockwise) from the watch housing.
    • There is an actual tool made to remove this back cover, using the right tool may save you from scratching the back of watch with tweezers. The backcover tool can be purchased online, a local jeweler may also be willing to remove it for you.
  3. Fossil Q Marshal Gen 2 Battery Replacement: paso 3, imagen 1 de 2 Fossil Q Marshal Gen 2 Battery Replacement: paso 3, imagen 2 de 2
    • Utilize tweezers or a spudger or your fingers to pull the black wire connector from the motherboard.
    • Utilize a spudger to pull the orange connector off of the motherboard.
  4. Fossil Q Marshal Gen 2 Battery Replacement: paso 4, imagen 1 de 1
    • Utilize tweezers to pull the white battery connector from the motherboard.
  5. Fossil Q Marshal Gen 2 Battery Replacement: paso 5, imagen 1 de 3 Fossil Q Marshal Gen 2 Battery Replacement: paso 5, imagen 2 de 3 Fossil Q Marshal Gen 2 Battery Replacement: paso 5, imagen 3 de 3
    • The internal electronics can now be pulled out of the watch as one unit leaving the screen remaining in the watch housing.
    • Taking the flat end of the spudger, pry it up.
  6. Fossil Q Marshal Gen 2 Battery Replacement, Battery: paso 6, imagen 1 de 1
    • The battery is secured to the back of the motherboard utilizing a sticky pad. Gently separate the battery from the board while making sure not to put too much stress on the board. This is best done at the location shown.
  7. Fossil Q Marshal Gen 2 Battery Replacement: paso 7, imagen 1 de 2 Fossil Q Marshal Gen 2 Battery Replacement: paso 7, imagen 2 de 2
    • Remove battery from plastic housing.
    • Slip wires through large slot in plastic housing to completely remove.
Conclusión
16 personas más completaron esta guía.
Clay Walker
Miembro Desde 11/07/17
752 Reputación
1 Guía escrita
Equipo
IUPUI, Team S2-G5, Harley Fall 2017 Miembro de IUPUI, Team S2-G5, Harley Fall 2017
IUPUI-HARLEY-F17S2G5
3 Miembros
6 Guías creadas
13 comentarios
I have read your awesome guide. This is really helpful.
https://powerbank-online.com/reviews/bat...
Ellen Sam - Contestar
thank you, i did it. But now what. i have no idea where to buy the spare part. hahaha. Help Me :(
Rafael “Satriabhi” Atheya - Contestar
I have the exact same battery I need to replace. easy to take out but where do I get the replacement battery??
dustykeith17 - Contestar
Help! I can’t find a replacement battery.
Pedro Pimentel - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 11
Ultimos 7 días: 91
Ultimos 30 días: 448
Todo El Tiempo: 38,290
