Saltar al contenido principal
Fosera Scandle 200 Charging Terminal Replacement
Qué necesitas
  1. Fosera Scandle 200 Charging Terminal Replacement, Motherboard Removal: paso 1, imagen 1 de 1
    • To open up the casing, you will need to unscrew the four Phillips #0 15mm screws which are accessible from the back.
  2. Fosera Scandle 200 Charging Terminal Replacement: paso 2, imagen 1 de 1
    • Gently separate the two halves of the casing.
  3. Fosera Scandle 200 Charging Terminal Replacement: paso 3, imagen 1 de 1
    • Disconnect the battery from the motherboard by lifting up on the white plastic tab on the top of the connection.
    • Gently pull the cord out by the white plastic adapter. Do not pull from the red and black cord.
  4. Fosera Scandle 200 Charging Terminal Replacement: paso 4, imagen 1 de 1
    • Unscrew the Phillips four #0 15mm screws to free the motherboard from the casing.
  5. Fosera Scandle 200 Charging Terminal Replacement: paso 5, imagen 1 de 1
    • Slowly pull the motherboard out of the casing. Make sure the loose battery wire doesn't get snagged.
  6. Fosera Scandle 200 Charging Terminal Replacement, Charging Terminal: paso 6, imagen 1 de 1
    • Use caution when using a soldering iron, the tip will be very hot.
    • Locate the charging terminal's three prong connectors on the back of the motherboard.
  7. Fosera Scandle 200 Charging Terminal Replacement: paso 7, imagen 1 de 1
    • Start melting the solder on each prong connector individually with the soldering iron.
  8. Fosera Scandle 200 Charging Terminal Replacement: paso 8, imagen 1 de 1
    • Use the flat end of the spudger to pry the charging terminal away from the motherboard.
Conclusión
Una persona más ha completado esta guía.
David
Miembro Desde 09/23/14
124 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 12-5, Blackwell Fall 2014 Miembro de USF Tampa, Team 12-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G5
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 393
