Saltar al contenido principal
FlySky FS-TH9X Joystick Replacement
Qué necesitas
  1. FlySky FS-TH9X Joystick Replacement, FlySky FS-TH9X Disassembly: paso 1, imagen 1 de 1
    • On the back of the remote, you will see 6 5mm Phillips #2 head screws.
    • The six screws on the front of the remote are screws that disconnect the joysticks from the remote and cannot be used to remove the back panel.
  2. FlySky FS-TH9X Joystick Replacement: paso 2, imagen 1 de 1
    • Using a size two Phillips screwdriver, remove the six 5 mm Phillips #2 head screws
  3. FlySky FS-TH9X Joystick Replacement: paso 3, imagen 1 de 1
    • Using a pry tool with a little pressure, carefully pull apart the remote to expose the inside.
  4. FlySky FS-TH9X Joystick Replacement: paso 4, imagen 1 de 1
    • Continue to troubleshooting your device.
  5. FlySky FS-TH9X Joystick Replacement, FlySky FS-TH9X Joystick: paso 5, imagen 1 de 1
  6. FlySky FS-TH9X Joystick Replacement: paso 6, imagen 1 de 1
    • Carefully remove chassis from outer casing.
  7. FlySky FS-TH9X Joystick Replacement: paso 7, imagen 1 de 1
    • Gently remove wiring from circuit.
    • To replace this part please contact the manufacturer, or consult the internet, to purchase parts.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 94
