Introducción
This guide helps you replace the Fluke 77 Series III Multimeter's PCA. The PCA is the main circuit board of the Multimeter and is therefore its most important part.
Qué necesitas
Turn the multimeter so it is display side down.
Lift up the back stand of the device by putting your thumb in the curved well at the bottom of the device, so you have access to the two covered screws below.
Locate the 9V battery in the lower right corner of the device.
Pull the battery out of its terminal.
Locate the fuses near the bottom left corner inside the device.
The .440 Amp fuse is located in the upper left hand fuse holder.
The 11 Amp fuse is located in the lower right hand fuse holder.
Lift the rounded edge of the fuse with one finger until that side is completely out of its holder.
Locate the rubber range and hold buttons in the internal assembly. These are found just below the LCD screen on the left hand side.
Remove the rubber range and hold button part with your thumb and forefinger.
Locate the silver 7 mm screw found underneath the 11A fuse.
Using the Phillips #0 Screwdriver, unscrew and remove the silver 7 mm Phillips #0 screw that attaches the back panel to the internal cover.
Turn the internal assembly over so that the green circuit board (PCA) is visible.
Locate the five silver 11 mm Phillips #1 screws on the upper part of the circuit board that hold it to the the grey plastic internal cover.
3 personas más completaron esta guía.
