Introducción
This guide helps you replace the Fluke 77 Series III Multimeter Dial. The dial is used to turn the multimeter on and off, and to switch between measuring modes.
Qué necesitas
Turn the multimeter so it is display side down.
Lift up the back stand of the device by putting your thumb in the curved well at the bottom of the device, so you have access to the two covered screws below.
Hold front panel with both hands, with your thumbs on the dial axle. The dial axle is the metal rod that comes out from the middle of the white plastic rotating piece.
Firmly press down on the dial axle to separate the dial from the front panel.
If this is difficult to do with your hands, push the dial axle against something hard, like the edge of a table.
3 personas más completaron esta guía.
