Introducción
If the battery on your Fluke 77 Series III Multimeter needs to be replaced, this guide details the steps for doing so. Replacing the battery is a routine, but critical part replacement for the Fluke 77 Series III Multimeter.
Qué necesitas
Turn the multimeter so it is display side down.
Lift up the back stand of the device by putting your thumb in the curved well at the bottom of the device, so you have access to the two covered screws below.
Locate the 9V battery in the lower right corner of the device.
Pull the battery out of its terminal.
5 personas más completaron esta guía.
