Saltar al contenido principal
Flip-Flop Line Strap Replacement
Qué necesitas
  1. Flip-Flop Line Strap Replacement, Line Strap: paso 1, imagen 1 de 1
    • Use the utility scissors to remove the tip of the broken line strap.
    • Try to remove as much of the broken tip as possible.
  2. Flip-Flop Line Strap Replacement: paso 2, imagen 1 de 1
    • Position one 8-inch zip tie underneath the strap line.
    • Head end of the zip tie.
    • Tail end of the zip tie.
    • You can use any color zip tie to match the color of your flip-flop.
    • Zip ties can be purchased from stores such as Walmart, Ace Hardware, and the Dollar Tree.
  3. Flip-Flop Line Strap Replacement: paso 3, imagen 1 de 1
    • Fold the zip tie so that the head end is on top of the line strap.
  4. Flip-Flop Line Strap Replacement: paso 4, imagen 1 de 1
    • Insert the tail end through the head end to make a loop.
  5. Flip-Flop Line Strap Replacement: paso 5, imagen 1 de 1
    • Tighten the loop by pulling on the tail end of the zip tie.
    • Make the loop approximately a half-inch.
  6. Flip-Flop Line Strap Replacement: paso 6, imagen 1 de 1
    • Cut off the extra zip tie material.
  7. Flip-Flop Line Strap Replacement: paso 7, imagen 1 de 1
    • Pass the metal flat washer through the second 8-inch zip tie.
    • 4.8mm metal flat washer.
  8. Flip-Flop Line Strap Replacement: paso 8, imagen 1 de 1
    • Pass the tail end through the hole on the bottom of the flip-flop.
  9. Flip-Flop Line Strap Replacement: paso 9, imagen 1 de 1
    • Pass the tail end through the loop of the first zip tie.
  10. Flip-Flop Line Strap Replacement: paso 10, imagen 1 de 2 Flip-Flop Line Strap Replacement: paso 10, imagen 2 de 2
    • Return the tail end back through the hole.
    • Pass the tail end into the 4.8mm metal flat washer.
    • Turn the flip-flop on its side for a better view.
  11. Flip-Flop Line Strap Replacement: paso 11, imagen 1 de 1
    • Push the 4.8mm metal flat washer inside the hole of the flip-flop.
  12. Flip-Flop Line Strap Replacement: paso 12, imagen 1 de 1
    • Insert the tail end into the head end.
  13. Flip-Flop Line Strap Replacement: paso 13, imagen 1 de 2 Flip-Flop Line Strap Replacement: paso 13, imagen 2 de 2
    • Adjust the length of the zip tie to create a snug fit between your toes.
    • Push the loop of the tail into the hole.
    • Pull on the tail end until you're satisfied with the length.
    • Turn the flip-flip over occasionally to check the length of the toe piece as needed.
    • Length of toe piece.
    • This step might take some trial and error.
  14. Flip-Flop Line Strap Replacement: paso 14, imagen 1 de 1
    • Push the head end into the hole of the flip-flop.
    • It's okay if the head end does not fit perfectly inside the hole. It will eventually fit deeper into the hole from walking.
  15. Flip-Flop Line Strap Replacement: paso 15, imagen 1 de 1
  16. Flip-Flop Line Strap Replacement: paso 16, imagen 1 de 1
    • Cut off about a 1-inch piece of heavy duty duct tape.
    • You can use any color heavy duty duct tape to match the color of your flip-flop.
  17. Flip-Flop Line Strap Replacement: paso 17, imagen 1 de 1
    • Wrap the 1-inch piece of heavy duty duct tape tightly around the toe piece of the flip-flop.
    • If you don't have heavy duty duct tape, use two pieces of regular duct tape.
Conclusión
Your flip-flops are now restored! If you decide that you don't want them, please consider donating them to a local charity organization.
6 personas más completaron esta guía.
2 comentarios
my faovert flip flops were riped by a cazey man at the swimming pool i saw him waht to do
Toby Robinson - Contestar
Awesome. Thank you!
Windogalaz - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 26
Ultimos 30 días: 83
Todo El Tiempo: 26,320
