Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Flip Video LCD Screen
Qué necesitas
  1. Flip Video LCD Screen, Outer Shell: paso 1, imagen 1 de 2 Flip Video LCD Screen, Outer Shell: paso 1, imagen 2 de 2
    • Turn off the device and take the batteries out.
    • Remove metal sticker under the LCD screen with a spudger.
    • This may require a large force to pry off the glued sticker.
  2. Flip Video LCD Screen: paso 2, imagen 1 de 1
    • Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
  3. Flip Video LCD Screen: paso 3, imagen 1 de 2 Flip Video LCD Screen: paso 3, imagen 2 de 2
    • Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
  4. Flip Video LCD Screen: paso 4, imagen 1 de 1
    • Open battery door. This can be done by gently depressing and sliding the battery down downward.
  5. Flip Video LCD Screen: paso 5, imagen 1 de 1
    • Use the spudger to separate outer shells.
    • The spudger must be inserted between the shell halves to pry the edges apart.
    • Slowly work around the outside to separate the halves.
  6. Flip Video LCD Screen, Circuit Board: paso 6, imagen 1 de 1
    • Remove the 3 5mm screws securing the circuit board to the front shell with the #00 Phillips screwdriver.
  7. Flip Video LCD Screen: paso 7, imagen 1 de 1
    • Slowly lift the left side of the circuit board.
    • Do not attempt to remove the circuit board completely yet. It is still connected to the device.
  8. Flip Video LCD Screen: paso 8, imagen 1 de 1
    • Disconnect the USB port cable from the back side of the circuit board.
  9. Flip Video LCD Screen: paso 9, imagen 1 de 1
    • Slide out the battery contacts.
    • Battery contacts
    • Slot where battery contacts were located
  10. Flip Video LCD Screen, LCD Screen: paso 10, imagen 1 de 1
    • With the LCD screen facing away from you, remove the 2 bronze 3 mm screws securing the LCD using the #00 Phillips screwdriver.
  11. Flip Video LCD Screen: paso 11, imagen 1 de 1
    • Flip over the circuit board and unlock the two black tabs on the ribbon connector by sliding them upwards.
  12. Flip Video LCD Screen: paso 12, imagen 1 de 1
    • Gently pull out ribbon cable.
    • If the ribbon cable does not come out easily you may not have fully unlocked the ribbon cable connector in the previous step.
    • The LCD screen is now removed and can be replaced.
Conclusión
Una persona más ha completado esta guía.
Elizabeth
Miembro Desde 04/15/10
100 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 26-21, Regan Spring 2010 Miembro de Cal Poly, Team 26-21, Regan Spring 2010
CPSU-REGAN-S10S26G21
Miembros de 4
12 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 28
Ultimos 30 días: 84
Todo El Tiempo: 5,619
