Saltar al contenido principal
Flip MinoHD USB Port Replacement
Qué necesitas
  1. Flip MinoHD USB Port Replacement, Battery: paso 1, imagen 1 de 2 Flip MinoHD USB Port Replacement, Battery: paso 1, imagen 2 de 2
    • With the Phillips screwdriver 000, unscrew the two small screws securing the battery to the outer case and set safely aside.
    • With the plastic opening tool, pry the battery out of device and set aside. Now the battery is fully removed.
  2. Flip MinoHD USB Port Replacement, USB Port: paso 2, imagen 1 de 3 Flip MinoHD USB Port Replacement, USB Port: paso 2, imagen 2 de 3 Flip MinoHD USB Port Replacement, USB Port: paso 2, imagen 3 de 3
    • Using Phillips screwdriver 000, unscrew the 4 screws from the outer casing. Now the small white microphone should disconnect and is free to be set aside.
    • With Phillips screwdriver 000, unscrew the 3 screws which secure the aluminum USB bracket.
    • Using tweezers, remove the USB port from the device. Your device is now a skeleton and is ready for replacement. To do so, follow these steps backwards.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 486
