Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Flash Motherboard
Qué necesitas
  1. Flash Motherboard, Front and Back Covers: paso 1, imagen 1 de 3 Flash Motherboard, Front and Back Covers: paso 1, imagen 2 de 3 Flash Motherboard, Front and Back Covers: paso 1, imagen 3 de 3
    • Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
    • There are 2 screws on the left side (when looking at the front of the camera).
    • There are 3 screws on the bottom
    • There is 1 screw on the right side
    Pregunta a FixBot
    Agregar Comentario
  2. Flash Motherboard: paso 2, imagen 1 de 1
    • Turn to the bottom of the camera.
    • Open the memory card cover by sliding the "CARD/BATT." button up, and then pulling the cover to the left.
    Pregunta a FixBot
    Agregar Comentario
  3. Flash Motherboard: paso 3, imagen 1 de 1
    • This is what the SD card/battery compartment looks like when opened.
    • Remove one 4.45mm phillips head screw from the SD card/battery compartment using a #00 phillips head screwdriver.
    Pregunta a FixBot
    Agregar Comentario
  4. Flash Motherboard: paso 4, imagen 1 de 2 Flash Motherboard: paso 4, imagen 2 de 2
    • Gently remove the front cover away from the camera body.
    • Tip: Start by loosening the teeth on the left side of the camera next to the battery compartment.
    Pregunta a FixBot
    Agregar Comentario
  5. Flash Motherboard: paso 5, imagen 1 de 1
    • The camera should look like this once the front cover is removed.
    Pregunta a FixBot
    Agregar Comentario
  6. Flash Motherboard: paso 6, imagen 1 de 3 Flash Motherboard: paso 6, imagen 2 de 3 Flash Motherboard: paso 6, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Start from the battery compartment and remove the back cover.
    • Caution: Do not tug on the back cover after it is removed. This could tear the ribbon attaching the back cover to the camera body.
    • Remove the connecting ribbon from the body of the camera using a pair of tweezers.
    Pregunta a FixBot
    Agregar Comentario
  7. Flash Motherboard: paso 7, imagen 1 de 1
    • Once the ribbon connecting the back cover is removed, the back of the camera body should look like this.
    Pregunta a FixBot
    Agregar Comentario
  8. Flash Motherboard, Flash Motherboard: paso 8, imagen 1 de 1
    • Turn to the front of the camera.
    • Find the flash motherboard located behind the flash assembly on the top right.
    Pregunta a FixBot
    Agregar Comentario
  9. Flash Motherboard: paso 9, imagen 1 de 1
    • Use a soldering iron and a desoldering wick to disconnect the wires from the marked locations.
    • Once the cables are disconnected, you are now ready to install a new motherboard.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
4 personas más completaron esta guía.
Jakub
Miembro Desde 04/19/11
134 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 8-6, Regan Spring 2011 Miembro de Cal Poly, Team 8-6, Regan Spring 2011
CPSU-REGAN-S11S8G6
Miembros de 4
22 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 48
Todo El Tiempo: 4,478
