Saltar al contenido principal
Fixing a Wobbly Armrest on the VonRacer Gaming Chair
Qué necesitas
  1. Fixing a Wobbly Armrest on the VonRacer Gaming Chair, Fixing a Wobbly Armrest on the VonRacer Gaming Chair: paso 1, imagen 1 de 3 Fixing a Wobbly Armrest on the VonRacer Gaming Chair, Fixing a Wobbly Armrest on the VonRacer Gaming Chair: paso 1, imagen 2 de 3 Fixing a Wobbly Armrest on the VonRacer Gaming Chair, Fixing a Wobbly Armrest on the VonRacer Gaming Chair: paso 1, imagen 3 de 3
    • To be able to reach the bolts on the bottom of the seat in an easily accessible manner, you should pull out the leg rest and recline the seat all the way back.
    • After doing so, put the chair on its side.
    • This is recommended to be able to have an easier time removing the screws.
  2. Fixing a Wobbly Armrest on the VonRacer Gaming Chair: paso 2, imagen 1 de 3 Fixing a Wobbly Armrest on the VonRacer Gaming Chair: paso 2, imagen 2 de 3 Fixing a Wobbly Armrest on the VonRacer Gaming Chair: paso 2, imagen 3 de 3
    • Remove the two 25 mm arm rest bolts with an M8 hex screwdriver.
    • Remove the arm rest.
  3. Fixing a Wobbly Armrest on the VonRacer Gaming Chair: paso 3, imagen 1 de 3 Fixing a Wobbly Armrest on the VonRacer Gaming Chair: paso 3, imagen 2 de 3 Fixing a Wobbly Armrest on the VonRacer Gaming Chair: paso 3, imagen 3 de 3
    • Tighten the three screws on the arm rest, one for the elbow joint and two for the arm rest cushion, with a Phillips #1 screwdriver.
    • Give the arm rest a shake to ensure there is no wobble in the two joints.
  4. Fixing a Wobbly Armrest on the VonRacer Gaming Chair: paso 4, imagen 1 de 3 Fixing a Wobbly Armrest on the VonRacer Gaming Chair: paso 4, imagen 2 de 3 Fixing a Wobbly Armrest on the VonRacer Gaming Chair: paso 4, imagen 3 de 3
    • Align the arm rest with the two screw holes on the bottom of the seat.
    • Replace the two 25 mm M8 hex screws to secure the arm rest.
    • Be sure to sufficiently tighten these screws to eliminate any wobble.
Conclusión
Una persona más ha completado esta guía.
Abdullahi Hassan
Miembro Desde 09/21/20
133 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 10
Ultimos 30 días: 62
Todo El Tiempo: 13,697
