Saltar al contenido principal
Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler
Qué necesitas
  1. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler, Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: paso 1, imagen 1 de 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler, Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: paso 1, imagen 2 de 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler, Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: paso 1, imagen 3 de 3
    • Turn your label-maker on its face. Using your thumb, press in and then upward on the fastener located on the side of your device.
  2. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: paso 2, imagen 1 de 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: paso 2, imagen 2 de 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: paso 2, imagen 3 de 3
    • Remove the batteries from your device.
  3. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: paso 3, imagen 1 de 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: paso 3, imagen 2 de 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: paso 3, imagen 3 de 3
    • Using a plastic opening tool from your iFixit tool kit, leverage the label cartridge out of your device.
  4. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: paso 4, imagen 1 de 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: paso 4, imagen 2 de 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: paso 4, imagen 3 de 3
    • Press the label paper back into alignment with the small holders on the right side of the label cartridge.
  5. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: paso 5, imagen 1 de 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: paso 5, imagen 2 de 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: paso 5, imagen 3 de 3
    • Place the label cartridge and batteries back into your device. Refasten the bottom case of the label-maker.
  6. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: paso 6, imagen 1 de 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: paso 6, imagen 2 de 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: paso 6, imagen 3 de 3
    • Well done! You have successfully corrected the paper-jam in your Brother PT-90 Label-Maker.
Conclusión
Kaitlyn Abrams
Miembro Desde 10/13/16
1 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 764
