Saltar al contenido principal
Introducción
This is a way that may be able to fix the problem that makecab.exe runs for a long time, slowing down the computer. There are also many articles about makecab.exe that you can google.
Time the problem occurred to me: May 2018 on my windows 7 home 64bit.
  1. Find CBS log files folder. The folder usually contains a .log file under 2 GB, and some .cab files.
    • Find CBS log files folder. The folder usually contains a .log file under 2 GB, and some .cab files.
  2. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  3. Delete, or move away if you want to keep the logs, any .log files larger than 2 GB in the CBS folder. If makecab.exe is currently running and processing the log files, you may need to end it through Task manager.
    • Delete, or move away if you want to keep the logs, any .log files larger than 2 GB in the CBS folder.
    • If makecab.exe is currently running and processing the log files, you may need to end it through Task manager.
Linea de Meta
Una persona más ha completado esta guía.
Somnic
Miembro Desde 13/07/18
105 Reputación
1 Guía escrita
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 13
Todo El Tiempo: 184
