Saltar al contenido principal
Fix a Loose Mounting Dream MD2462 TV Wall Mount
Qué necesitas
  1. Fix a Loose Mounting Dream MD2462 TV Wall Mount, Fix a Loose Mounting Dream MD2462 TV Wall Mount: paso 1, imagen 1 de 3 Fix a Loose Mounting Dream MD2462 TV Wall Mount, Fix a Loose Mounting Dream MD2462 TV Wall Mount: paso 1, imagen 2 de 3 Fix a Loose Mounting Dream MD2462 TV Wall Mount, Fix a Loose Mounting Dream MD2462 TV Wall Mount: paso 1, imagen 3 de 3
    • Remove the two M4x5mm bolts on the back of the TV plate using a Phillips #00 screwdriver.
    • Unplug the TV cables before removing the TV from the wall.
  2. Fix a Loose Mounting Dream MD2462 TV Wall Mount: paso 2, imagen 1 de 3 Fix a Loose Mounting Dream MD2462 TV Wall Mount: paso 2, imagen 2 de 3 Fix a Loose Mounting Dream MD2462 TV Wall Mount: paso 2, imagen 3 de 3
    • Remove the three lag bolts from the wall mount by using a 13mm open-end wrench.
    • If it is too loose, it can just be pulled out.
  3. Fix a Loose Mounting Dream MD2462 TV Wall Mount: paso 3, imagen 1 de 3 Fix a Loose Mounting Dream MD2462 TV Wall Mount: paso 3, imagen 2 de 3 Fix a Loose Mounting Dream MD2462 TV Wall Mount: paso 3, imagen 3 de 3
    • Fill the holes where the screws were secured using drywall spackle.
  4. Fix a Loose Mounting Dream MD2462 TV Wall Mount: paso 4, imagen 1 de 1
    • Locate the wooden studs on the wall using a stud finder or knock on the wall to see if the stud is behind the wall.
  5. Fix a Loose Mounting Dream MD2462 TV Wall Mount: paso 5, imagen 1 de 3 Fix a Loose Mounting Dream MD2462 TV Wall Mount: paso 5, imagen 2 de 3 Fix a Loose Mounting Dream MD2462 TV Wall Mount: paso 5, imagen 3 de 3
    • Use a pencil to mark three holes on the wall.
    • Use a 3/8-inch drill bit to drill three holes at the marked positions.
    • Secure the wall mount into the wooden studs using new screws or bolts.
    • Ensure that all the screws are firmly secured to the wooden stud.
  6. Fix a Loose Mounting Dream MD2462 TV Wall Mount: paso 6, imagen 1 de 2 Fix a Loose Mounting Dream MD2462 TV Wall Mount: paso 6, imagen 2 de 2
    • Test the firmness of the TV wall mount by gently pushing it up and down.
  7. Fix a Loose Mounting Dream MD2462 TV Wall Mount: paso 7, imagen 1 de 2 Fix a Loose Mounting Dream MD2462 TV Wall Mount: paso 7, imagen 2 de 2
    • Gently replace the TV back on the wall mount.
  8. Fix a Loose Mounting Dream MD2462 TV Wall Mount: paso 8, imagen 1 de 1
    • Make sure the TV is secure and well-centered on the wall mount using a spirit level gauge to confirm the inclination.
Conclusión
Una persona más ha completado esta guía.
Emmanuel Emedeke
Miembro Desde 09/17/20
184 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 41
Todo El Tiempo: 5,092
