Introducción
When you power up the router, after 4 seconds the power light changes from green to yellow.
Sometimes this is related to a corrupted firmware, but other times is related to a faulty power supply.
In this guide I'll show you how to diagnose this issue and fix by replacing one single component from the power supply.
Qué necesitas
Insert your X-Acto knife on the groove in order to remove part of the glue that is holding the two parts.
Using your prying tools or a butter knife, slide it in and then bend it until you ear it pop.
On the board of the power supply you'll probably see the faulty capacitor. Is the one on the right that has swollen.
Using the soldering iron, desolder the faulty capacitor and solder a new one.
Reassemble the power supply and your router should be back and running fine :)
