• First, determine if the problem is occurring due to water damage. To do that, look at the battery and see if the water indicator (red or blue) has been activated. If so, go to the next step.
    • Then, remove the battery from the phone.
    • Using a blow dryer, blow warm air on both the battery and the remainder of the device for about three minutes.
  1. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
    ¿Alguna vez arreglaste algo? Eso es genial.
    Comparte tu historia de reparación con #SoyUnGenio
    Todos somos Genios
    • Bring two zip lock bags and fill them with 2 cups of either salt or rice.
    • Put the battery in one of the two bags and put the rest of the device in the other one.
    • Close the bags well so that they are airtight. Then place the bags in a dark dry spot for about a week. Make sure to be patient because the process of evaporating moisture takes a very long time.
    • Wait one week. Retrieve the bags. Open the bags and reconnect the battery with the body of the Motorola Adventure V750. Though the moisture indicator may still say the battery is wet, connect the battery back to the device and continue to turn on the phone.
    • If problem still exists, consider purchasing new battery and installing it with the old device.
Conclusión
Una persona más ha completado esta guía.
Kyle
Miembro Desde 01/10/12
572 Reputación
5 Guías creadas
Equipo
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 1
Todo El Tiempo: 309
