Saltar al contenido principal
Five Steps To Apply A New OCA On Samsung Galaxy Note 8 Edge Touch Glass
Qué necesitas
Resumen del Video
  1. Five Steps To Apply A New OCA On Samsung Galaxy Note 8 Edge Touch Glass, Put a new OCA: paso 1, imagen 1 de 2 Five Steps To Apply A New OCA On Samsung Galaxy Note 8 Edge Touch Glass, Put a new OCA: paso 1, imagen 2 de 2
    • We put a new OCA on a new Samsung Galaxy Note 8 touch screen. It doesn’t paste on the touch screen because the protector of the OCA is no need to be torn off. And you can move the OCA around until you get the right place.
  2. Five Steps To Apply A New OCA On Samsung Galaxy Note 8 Edge Touch Glass, Using upper mold: paso 2, imagen 1 de 2 Five Steps To Apply A New OCA On Samsung Galaxy Note 8 Edge Touch Glass, Using upper mold: paso 2, imagen 2 de 2
    • Then we put the upper mold on the base one after we align the position and continue to press it with our hands.
    • At this moment, the OCA is absorbed on the upper mold.
  3. Five Steps To Apply A New OCA On Samsung Galaxy Note 8 Edge Touch Glass, Remove the protector of the OCA: paso 3, imagen 1 de 1
    • Remove the protector of the OCA
  4. Five Steps To Apply A New OCA On Samsung Galaxy Note 8 Edge Touch Glass, Remove protector of the new touch screen: paso 4, imagen 1 de 1
    • For this step, we can use an easy tape to tear off the protector of the touch screen.
  5. Five Steps To Apply A New OCA On Samsung Galaxy Note 8 Edge Touch Glass, Using lamination machine: paso 5, imagen 1 de 2 Five Steps To Apply A New OCA On Samsung Galaxy Note 8 Edge Touch Glass, Using lamination machine: paso 5, imagen 2 de 2
    • After finishing the above steps, we put the whole set of mold into RMB-2 Laminating Machine for bonding.
    • For the whole process, the vacuum time we set is 30s and the lamination time is 10s, the total time for the lamination only needs 40s.
    • Now let’s see the final result after the lamination. There is no any bubble on the touch screen and the OCA’s position is completely unbiased and exactly overlap with touch screen. So the lamination effect is excellent.
Conclusión
Why we say this mold is so effective? As during the bonding or before the bonding, the protector of the OCA doesn’t need to be ripped off. It is very precise and accurate because you can move and align the position optionally until you get a best place.
4 personas más completaron esta guía.
FORWARD Lab
Miembro Desde 04/17/20
1,414 Reputación
9 Guías creadas
2 comentarios
Thanks for that useful informations……. Also visit
(https://rb.gy/hmx3oc)
Selma Dietheimer - Contestar
thanks for your appreciate
FORWARD Lab -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 25
Ultimos 30 días: 95
Todo El Tiempo: 7,036
