Saltar al contenido principal
Fitbit Charge HR Vibration Motor Replacement
Qué necesitas
  1. Fitbit Charge HR Vibration Motor Replacement, Vibration Motor: paso 1, imagen 1 de 1
    • Remove the four 2.9 mm screws from the back of the display using a Torx screwdriver.
    • Remove the back cover from the device.
  2. Fitbit Charge HR Vibration Motor Replacement: paso 2, imagen 1 de 3 Fitbit Charge HR Vibration Motor Replacement: paso 2, imagen 2 de 3 Fitbit Charge HR Vibration Motor Replacement: paso 2, imagen 3 de 3
    • Remove the two 2.9 mm Torx screws holding the circuit board in place.
    • Carefully pry the board out using an opening tool.
  3. Fitbit Charge HR Vibration Motor Replacement: paso 3, imagen 1 de 1
    • Remove the motherboard assembly from the device by gently lifting.
  4. Fitbit Charge HR Vibration Motor Replacement: paso 4, imagen 1 de 2 Fitbit Charge HR Vibration Motor Replacement: paso 4, imagen 2 de 2
    • Locate the vibration motor on the motherboard.
    • Desolder the red and black wires connected to the motherboard from the vibration motor.
    • Red wire is located closer to the outside. Black wire is closer to the inside of the motherboard.
    • Replace with new vibration motor.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 490
