Saltar al contenido principal
Qué necesitas
Este desmontaje no es una guía de reparación. Para reparar tu Fitbit Charge HR, utiliza nuestros manuales de servicio .
  1. Fitbit Charge HR Teardown, Remove Screws: paso 1, imagen 1 de 1
    • Take the 4 Screws out of the Sides you will need a T3 star Screw Driver
  2. Fitbit Charge HR Teardown: paso 2, imagen 1 de 2 Fitbit Charge HR Teardown: paso 2, imagen 2 de 2
    • You Pry out the Main board you can see the Metal Hooks
  3. Fitbit Charge HR Teardown: paso 3, imagen 1 de 1
    • You can Then pull out the Screws from around the Screen
Bradley Nelson
Miembro Desde 03/08/16
56 Reputación
1 Guía escrita
8 comentarios
Can the battery be replaced?
Rick - Contestar
Mine was just over a year old (barely out of warranty) when it died. The Fitbit folks were kind enough to replace it anyway once I expressed my displeasure. I'd haggle with them a bit before going the DIY route but I'm definitely keeping my old one for spare parts. Hopefully someone will point out an aftermarket battery source before I need to do that.
fragmasterflash - Contestar
The screws in mine were Torx T-2, not T-3.
Jake McIvor - Contestar
The button is stuck in my ChargeHR. I bought the T3 screwdriver and it is too big. Either the screws are T2 or my screwdriver is too much imprecise.
Anyone fixed a stuck button?
Anderson Maciel - Contestar
it definitely not T3 must be T2
Marc Frederick - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 16
Todo El Tiempo: 23,963
