Saltar al contenido principal
Introducción
This is a simple tear down & repair tutorial for the Fitbit Charge HR. Illustrated is the replacing of a weak or dead battery.
  1. Inside your Fitbit Charge HR Inside your Fitbit Charge HR
    • Inside your Fitbit Charge HR
  2. You'll need some plastic bits to separate the band, plus a torx driver, new battery and a soldering iron.
    • You'll need some plastic bits to separate the band, plus a torx driver, new battery and a soldering iron.
  3. This repair only works on the Fitbit Charge HR model, not the older Charge without heart rate. The batteries are different.
    • This repair only works on the Fitbit Charge HR model, not the older Charge without heart rate. The batteries are different.
  4. Start by removing the 4 torx screws
    • Start by removing the 4 torx screws
  5. The assembly is briskly snapped into place. You'll need to separate the sides of the housing with a small plastic tool and your finger nail (or two plastics). Be careful, as the housing can fracture with too much force.
    • The assembly is briskly snapped into place. You'll need to separate the sides of the housing with a small plastic tool and your finger nail (or two plastics). Be careful, as the housing can fracture with too much force.
  6. Once removed, there are 2 torx screws holding the circuit board in place.  Remove these, and carefully pry the board out Once removed, there are 2 torx screws holding the circuit board in place.  Remove these, and carefully pry the board out
    • Once removed, there are 2 torx screws holding the circuit board in place. Remove these, and carefully pry the board out
  7. The Fitbit is very light and hard to hold, so it is recommended to tape the board in place when soldering. The Fitbit is very light and hard to hold, so it is recommended to tape the board in place when soldering.
    • The Fitbit is very light and hard to hold, so it is recommended to tape the board in place when soldering.
  8. Note: You can permanently damage your device. Be careful with the assembly, and splice one or both wires before removing the old battery to prevent a short. Do not mistake the round buzzer for a battery. It is not !
    • Note: You can permanently damage your device. Be careful with the assembly, and splice one or both wires before removing the old battery to prevent a short. Do not mistake the round buzzer for a battery. It is not !
  9. After replacing the bad battery, plug in the charger for at least 20 minutes. Then remove the charger to confirm you have a working replacement.
    • After replacing the bad battery, plug in the charger for at least 20 minutes. Then remove the charger to confirm you have a working replacement.
Conclusión
30 personas más completaron esta guía.
martysummer
Miembro Desde 18/02/13
883 Reputación
1 Guía escrita
20 comentarios
if you have the manual dexterity and intellect to replace the battery on a Fit bit Charge HR, why can't you do it on. "Charge" plain model I have 3 of these with dead batteries?
coljwm - Contestar
The battery on the original Fitbit tracker is different than the newer Fitbit HR. If you can find a battery that fits, it would work.
martysummer - Contestar
Where can I buy a replacement battery for my charge hr? Fitbit wants me to buy a new Fitbit which is inexcusable since the watch is only 16 months old
Evan - Contestar
They sell them on Amazon for $10.95. Has only one review for 2 stars. Trying to decide if I should order one. Caveat emptor!
Scott McKernon -
Can you give me the size of the battery?
Bajmóczy Géza - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 18
Ultimos 7 días: 128
Ultimos 30 días: 629
Todo El Tiempo: 135,804
