Introducción
Have a faulty battery with charging problems or just poor battery life? This guide will help you step by step in replacing your battery. Note soldering will be required, please follow this wonderful guide for helpful tips.
Qué necesitas
Place device screen face down and locate the four screws attaching the back cover.
Use a T3 torx head or T3 torx screwdriver to remove the four screws.
Lift and push the motherboard to the side to uncover the 167mAh battery.
Use a plastic spudger tool to pry out the battery from its adhesive plastic underneath.
Lift up and pull downward to remove battery. Switch to the top portion of the battery and push downward to pry out battery.
Flip the motherboard backwards and locate the metal pins from the battery soldered to the board.
Desolder the connection to remove the battery, desolder the battery connector itself if desired as well.
Follow this guide on how to solder and desolder connectors Soldering Guide
62 personas más completaron esta guía.
55 Guide Comments
Where can I buy this battery?
Please contact fred@doble.com.br
no answer for:
Looking for this battery as well; mine lasted exactly 1 year. 7 days now down to hours, the surge did the same thing, maybe my last Fitbit watch ever! Disappointed to say the least.
I found a battery, 3.7 volt at 165mAh in the same style, should be close enough but I do not have the size of the factory battery, if anyone has taken theirs apart, can you post up the measurements in mm? thanks
I can't find the battery anywhere either. Would love some advice. Tried Amazon, AliExpress, eBay and Google in general.
