Introducción
This guide will help you step by step in replacing your damaged vibrating motor. Note soldering will be required, please follow this wonderful guide for helpful tips. Soldering Connectors
Qué necesitas
Locate the pin behind the second wristband located on the edge of metal ring.
Insert the pointed end of the metal spudger into the pin hold and push it into opposite direction.
Remove wristband.
Place device screen face down and locate the four screws attaching the back cover.
Use a T3 torx head or T3 torx screwdriver to remove the four screws.
Flip the motherboard back to the front to locate the metal pins from the vibration motor soldered to the board.
Desolder the connection to remove the motor component.
Follow this guide on how to solder and desolder connectors Soldering Guide
