Qué necesitas
Place the scale upside down on a surface that will protect the glass top of the scale and won’t scratch.
Remove the battery cover and batteries (if installed).
Remove the label in the battery compartment. You can use a small flat headed screwdriver or similar implement to pry the sticker up. (Try to avoid damaging the sticker too much if possible).
Use a Torx T10 screwdriver to remove the two Torx screws and set aside.
Using a small flathead screwdriver, starting new the corners, pry away the plastic panel from the glass top.
Once the gap is wider use larger pry tools to allow you to pull the bottom section away. You may need to use some force to release the clips.
Note there are no cables of components connected to the bottom plate so do not be concerned about ripping delicate cables.
Once open necessary repairs can be made.
If your issue is regarding inaccurate measurement you can remove the feet by pulling them, then remove the feet mounts using a small flat headed screwdriver to release the three clips.
Reassemble the feet and feet mounts outside of the unit then reseat them in the clips.
