Saltar al contenido principal
Fitbit Alta Wristband Replacement
  1. Fitbit Alta Wristband Replacement, Wristband: paso 1, imagen 1 de 1
    • To release a latch, press down on the flat metal button holding the band to the Fitbit Alta. Pull up on the latch to release the band from the body.
  2. Fitbit Alta Wristband Replacement: paso 2, imagen 1 de 1
    • Slide the band up to release it from the Fitbit Alta tracker. Then, repeat on the other side to remove the band.
  3. Fitbit Alta Wristband Replacement: paso 3, imagen 1 de 3 Fitbit Alta Wristband Replacement: paso 3, imagen 2 de 3 Fitbit Alta Wristband Replacement: paso 3, imagen 3 de 3
    • Turn over the Fitbit Alta so the bands are facing upward.
    • Press the latches inward and remove each band by lifting upward.
Conclusión
To reassemble your device, follow these instructions in reverse order. When you hear a click , the wristband is secure.
13 personas más completaron esta guía.
2 comentarios
Excellent! Thanks so much!
JUDITH DIGENOVA - Contestar
My band broke off and the tab used for removal broke and I cannot get my remnant of my band off. What are the steps for removing the band if the tab is broken?
godz.gal.52 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 38
Todo El Tiempo: 11,804
