Saltar al contenido principal
Fitbit Alta HR Battery Replacement
Qué necesitas
  1. Fitbit Alta HR Battery Replacement, Remove straps: paso 1, imagen 1 de 2 Fitbit Alta HR Battery Replacement, Remove straps: paso 1, imagen 2 de 2
    • Push in the clip and slide off the strap from each side.
  2. Fitbit Alta HR Battery Replacement, Remove front cover: paso 2, imagen 1 de 1
    • Use a spudger to remove the front cover.
  3. Fitbit Alta HR Battery Replacement, Lift display: paso 3, imagen 1 de 1
    • Use a spudger to lift the display.
  4. Fitbit Alta HR Battery Replacement, Disconnect heart rate monitor: paso 4, imagen 1 de 1
    • Use a spudger to disconnect the cable that connects the heart rate monitor to the motherboard.
  5. Fitbit Alta HR Battery Replacement, Remove screws from motherboard: paso 5, imagen 1 de 1
    • Use a hex 0.7 screwdriver to remove the screws from the motherboard.
  6. Fitbit Alta HR Battery Replacement, Lift motherboard: paso 6, imagen 1 de 2 Fitbit Alta HR Battery Replacement, Lift motherboard: paso 6, imagen 2 de 2
    • Use a spudger to lift the motherboard.
  7. Fitbit Alta HR Battery Replacement, Lift battery and remove innards: paso 7, imagen 1 de 1
    • Use a spudger to lift the battery.
    • When the battery is lifted, the connected components (display, motherboard, battery) will come out.
    • Use a soldering iron to desolder the two battery contacts from the motherboard.
    • Ensure positive and negative wires are in the correct positions. There are + and – signs on the motherboard. Red is positive. Black is negative.
    • Use a soldering iron and lead-free solder to solder the new battery to the motherboard.
Conclusión
3 personas más completaron esta guía.
Wendy Sato
Miembro Desde 11/12/16
229 Reputación
1 Guía escrita
Un comentario
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 20
Ultimos 30 días: 82
Todo El Tiempo: 1,749
