Saltar al contenido principal
First Act MA2039 Speaker Replacement
Qué necesitas
  1. First Act MA2039 Speaker Replacement, Speaker: paso 1, imagen 1 de 1
    • Use a Phillips #0 screwdriver to remove the two 25mm screws that secure back panel to amplifier.
  2. First Act MA2039 Speaker Replacement: paso 2, imagen 1 de 2 First Act MA2039 Speaker Replacement: paso 2, imagen 2 de 2
    • Once screws are removed, lift the panel from the amplifier and feed the battery terminals through holes in battery cartridges.
    • Take the panel off and set it to the side.
  3. First Act MA2039 Speaker Replacement: paso 3, imagen 1 de 1
    • Use a Phillips #0 screwdriver to remove the four 25mm screws that fasten the speaker to the inside of the amplifier.
  4. First Act MA2039 Speaker Replacement: paso 4, imagen 1 de 1
    • Desolder the black and white speaker wires from the contact board.
    • The speaker can now be completely removed from the amplifer.
Conclusión
To reassemble your device, use soldering link provided to solder existing wires onto new speaker, then follow these instructions in reverse order.
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 417
