Saltar al contenido principal
First Act MA2039 Damaged Wire Replacement
Qué necesitas
  1. First Act MA2039 Damaged Wire Replacement, First Act MA2039 Damaged Wire Replacement: paso 1, imagen 1 de 2 First Act MA2039 Damaged Wire Replacement, First Act MA2039 Damaged Wire Replacement: paso 1, imagen 2 de 2
    • Place the speaker with its front side facing down.
    • Use a Phillips #0 screwdriver to remove the two 25 mm screws from the left and right sides of the battery cartridges.
    • Open both lids to the battery cartridges.
  2. First Act MA2039 Damaged Wire Replacement: paso 2, imagen 1 de 3 First Act MA2039 Damaged Wire Replacement: paso 2, imagen 2 de 3 First Act MA2039 Damaged Wire Replacement: paso 2, imagen 3 de 3
    • As you begin to lift the back panel off the amplifier, push the battery terminals through the open slots of the battery cartridges.
    • Use your fingers to prop the back panel and lift it away from the amplifier.
    • Lift the back panel off completely and set it to the side.
  3. First Act MA2039 Damaged Wire Replacement: paso 3, imagen 1 de 3 First Act MA2039 Damaged Wire Replacement: paso 3, imagen 2 de 3 First Act MA2039 Damaged Wire Replacement: paso 3, imagen 3 de 3
    • With the back panel off, this will help make space for the silver compartment to be removed.
    • Unscrew four 25 mm screws with a Phillips #0 screwdriver from the top of the amplifier.
    • Press firmly on the input jack and tone adjustment knob of the silver compartment to free it from its resting position.
  4. First Act MA2039 Damaged Wire Replacement: paso 4, imagen 1 de 3 First Act MA2039 Damaged Wire Replacement: paso 4, imagen 2 de 3 First Act MA2039 Damaged Wire Replacement: paso 4, imagen 3 de 3
    • Rotate the silver compartment so that you have a clear visual of the motherboard and its components.
    • For effective work on the wiring, lodge the compartment on top of the back portion of the amplifier.
    • Check the wiring components for blown fuses or damaged connections.
  5. First Act MA2039 Damaged Wire Replacement: paso 5, imagen 1 de 1
    • Lift the silver compartment to see where the wires are further connected.
    • Make sure that the terminals from the circuit to the amplifier are connected securely.
    • Check to see if there is loose wiring from the motherboard.
    • If there is damaged wire to the amplifier or motherboard in the silver compartment, refer this Soldering guide to replace wires and fix connections.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 11
Todo El Tiempo: 360
