Saltar al contenido principal
First Act MA2039 Cleaning Acid Residue
Qué necesitas
  1. First Act MA2039 Cleaning Acid Residue, First Act MA2039 Cleaning Acid Residue: paso 1, imagen 1 de 2 First Act MA2039 Cleaning Acid Residue, First Act MA2039 Cleaning Acid Residue: paso 1, imagen 2 de 2
    • There are several items you will need before starting. You will need: a pair of cleaning gloves, safety glasses, a screwdriver, a metal prying spudger (see picture 2), several Q-tips, distilled vinegar, 2 nine-volt batteries (for replacing damaged batteries), and one small plastic bag.
  2. First Act MA2039 Cleaning Acid Residue: paso 2, imagen 1 de 2 First Act MA2039 Cleaning Acid Residue: paso 2, imagen 2 de 2
    • Before starting, put on the cleaning gloves and safety glasses.
    • WARNING: battery acid from corroded batteries can cause skin and eye irritation depending on contact.
    • If you touch any battery acid wash hands thoroughly with with lukewarm water and handsoap.
    • If acid is splashed into your eye run lukewarm water from a faucet onto eye for 30 minutes with eyelids open.
  3. First Act MA2039 Cleaning Acid Residue: paso 3, imagen 1 de 3 First Act MA2039 Cleaning Acid Residue: paso 3, imagen 2 de 3 First Act MA2039 Cleaning Acid Residue: paso 3, imagen 3 de 3
    • Place the amplifier face-down and lift the cartridge lid up.
    • Remove the corroded battery with the assistance of the Spudger and place the battery in the plastic bag.
  4. First Act MA2039 Cleaning Acid Residue: paso 4, imagen 1 de 2 First Act MA2039 Cleaning Acid Residue: paso 4, imagen 2 de 2
    • Close the lid of the battery cartridge and begin to unscrew the two 13mm screws located at the top and bottom of the battery cartridge with the Phillips #0 Screwdriver.
    • Use the Spudger to pry the battery cartridge away from the center console.
  5. First Act MA2039 Cleaning Acid Residue: paso 5, imagen 1 de 3 First Act MA2039 Cleaning Acid Residue: paso 5, imagen 2 de 3 First Act MA2039 Cleaning Acid Residue: paso 5, imagen 3 de 3
    • Dab one end of the Q-tip into the vinegar solution.
    • Rub the inside and outside of the battery cartridge as well as the battery terminal with the Q-tip to remove any acid residue. Use as many Q-tips needed to remove the acid.
    • Once finished place the used Q-tip(s) inside the small bag with the battery and dispose of the two properly.
    • All done! Return the cartridge back into the center console and screw in the two 13mm screws.
Linea de Meta
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 10
Todo El Tiempo: 257
