Saltar al contenido principal
FirsTime Wall Clock Movemement Mechanism Replacement
Qué necesitas
  1. FirsTime Wall Clock Movemement Mechanism  Replacement, Movemement Mechanism: paso 1, imagen 1 de 2 FirsTime Wall Clock Movemement Mechanism  Replacement, Movemement Mechanism: paso 1, imagen 2 de 2
    • Using a Phillips #1 screwdriver, remove all four screws on the back of the clock.
  2. FirsTime Wall Clock Movemement Mechanism  Replacement: paso 2, imagen 1 de 1
    • Once screws are removed, simply remove the glass lens covering the display of the clock by lifting it with your hands.
  3. FirsTime Wall Clock Movemement Mechanism  Replacement: paso 3, imagen 1 de 2 FirsTime Wall Clock Movemement Mechanism  Replacement: paso 3, imagen 2 de 2
    • Turn the display face up.
    • Use needle nose pliers to pull off the 'second' hand.
  4. FirsTime Wall Clock Movemement Mechanism  Replacement: paso 4, imagen 1 de 2 FirsTime Wall Clock Movemement Mechanism  Replacement: paso 4, imagen 2 de 2
    • Use needle nose pliers to remove the 'minute' hand.
    • Then use needle nose pliers to remove the 'hour' hand.
  5. FirsTime Wall Clock Movemement Mechanism  Replacement: paso 5, imagen 1 de 1
    • Once all hands are removed, use a 7/16-inch wrench to unscrew, in counter clockwise direction, the threaded nut in the center of the clock.
    • Removing the threaded nut is what allows the movement mechanism to be removed from the clock.
  6. FirsTime Wall Clock Movemement Mechanism  Replacement: paso 6, imagen 1 de 2 FirsTime Wall Clock Movemement Mechanism  Replacement: paso 6, imagen 2 de 2
    • Lift the washer underneath the nut with your fingers.
  7. FirsTime Wall Clock Movemement Mechanism  Replacement: paso 7, imagen 1 de 1
    • Now you may remove the display of the clock from your malfunctioning movement mechanism.
Conclusión
20 personas más completaron esta guía.
5 comentarios
Is there a you tube showing these steps?
Patricia Ander - Contestar
Thank you! there was one tricky thing—the parts I got in the order did not match what I took off, so I had to reconfigure it a bit per new instructions that came with the parts. But I figured it out! Thank you for this instruction.
Leslie Benitez - Contestar
Excellent illustrations!!!
KO SAMUEL TAK SHUN - Contestar
there seem to be 2 projections keeping the back & glass together.
I don't want to break them.
Marcia Kaminski - Contestar
Where can I buy the exact clock?
Barb - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 13
Ultimos 7 días: 75
Ultimos 30 días: 343
Todo El Tiempo: 8,802
