Saltar al contenido principal
Fender Starcaster String Removement
Sólo Prerrequisito
Esta guía solo debería usarse como prerrequisito para otras guías. Por tanto, estará incompleta.
Qué necesitas
  1. Fender Starcaster String Removement, Loosen the Strings: paso 1, imagen 1 de 3 Fender Starcaster String Removement, Loosen the Strings: paso 1, imagen 2 de 3 Fender Starcaster String Removement, Loosen the Strings: paso 1, imagen 3 de 3
    • Start by loosening the strings. This is done by turning the tuning knob until the string has lost tension.
    • Repeat this for all six strings on the guitar.
  2. Fender Starcaster String Removement, Remove the Strings from the Tuning Pegs: paso 2, imagen 1 de 2 Fender Starcaster String Removement, Remove the Strings from the Tuning Pegs: paso 2, imagen 2 de 2
    • Be mindful of the string ends. They may be sharp and could puncture your skin.
    • It may be necessary to use pliers to remove string ends from the tuning peg.
  3. Fender Starcaster String Removement, Remove the Strings from the Bridge: paso 3, imagen 1 de 3 Fender Starcaster String Removement, Remove the Strings from the Bridge: paso 3, imagen 2 de 3 Fender Starcaster String Removement, Remove the Strings from the Bridge: paso 3, imagen 3 de 3
    • After removing the strings from the tuning pegs, slide the strings through the bridge and out of the back of the guitar.
    • If the twists in the string ends are in the way, use wire cutters to snip them off. This will allow the heavier strings to pass through the bridge easier.
Linea de Meta
Una persona más ha completado esta guía.
Equipo
Pasco Hernando, Team 5-3, Prince Fall 2014 Miembro de Pasco Hernando, Team 5-3, Prince Fall 2014
PHSC-PRINCE-F14S5G3
9 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 10
Todo El Tiempo: 2,373
