Saltar al contenido principal
Fender Jazz Bass Strings Replacement
Qué necesitas
  1. Fender Jazz Bass Strings Replacement, Strings: paso 1, imagen 1 de 1
    • Loosen the strings by turning the tuning pegs.
  2. Fender Jazz Bass Strings Replacement: paso 2, imagen 1 de 1
    • Once the strings are loose, remove them from the tuning pegs.
    • If you prefer, you can also cut the strings off.
  3. Fender Jazz Bass Strings Replacement: paso 3, imagen 1 de 2 Fender Jazz Bass Strings Replacement: paso 3, imagen 2 de 2
    • Reach under the bridge to pull out the end of each string.
  4. Fender Jazz Bass Strings Replacement: paso 4, imagen 1 de 2 Fender Jazz Bass Strings Replacement: paso 4, imagen 2 de 2
    • Insert the end of the string with no knob on the bottom through the bridge first.
    • Pull each string through to the top of the neck.
  5. Fender Jazz Bass Strings Replacement: paso 5, imagen 1 de 1
    • Insert the strings into the indentations on the nut.
    • Wrap the strings around the tuning pegs about two times.
  6. Fender Jazz Bass Strings Replacement: paso 6, imagen 1 de 2 Fender Jazz Bass Strings Replacement: paso 6, imagen 2 de 2
    • Tighten the tuning pegs until the bass is in tune.
    • The standard tuning for a bass is E A D G.
    • You will have excess string hanging off the pegs of the bass.
Linea de Meta
Una persona más ha completado esta guía.
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 30
Todo El Tiempo: 508
