Saltar al contenido principal
Fender Frontman 15r Speaker Replacement
Qué necesitas
  1. Fender Frontman 15r Speaker Replacement, Back panel: paso 1, imagen 1 de 1
    • Be sure to unplug the device before proceeding.
    • Use a Phillips #0 screwdriver to remove the four 21.7mm screws holding the back panel to the frame.
  2. Fender Frontman 15r Speaker Replacement: paso 2, imagen 1 de 1
    • Once the screws are out, use a plastic opening tool or spudger to pry the top of the back panel open. There may be some resistance, but it will eventually pry loose.
  3. Fender Frontman 15r Speaker Replacement: paso 3, imagen 1 de 1
    • Once the top is separated, use your hand to remove the back panel from the unit.
  4. Fender Frontman 15r Speaker Replacement, Speaker: paso 4, imagen 1 de 1
    • Using tape or a post-it, label the input and output wires on the reverb. Remove these wires from the box.
  5. Fender Frontman 15r Speaker Replacement: paso 5, imagen 1 de 1
    • Remove the two female connection terminals from the speaker terminals.
  6. Fender Frontman 15r Speaker Replacement: paso 6, imagen 1 de 1
    • Use a Philips #1 screwdriver to remove the four 21.9 mm Phillips screws from the perimeter of the speaker.
  7. Fender Frontman 15r Speaker Replacement: paso 7, imagen 1 de 2 Fender Frontman 15r Speaker Replacement: paso 7, imagen 2 de 2
    • Gently remove the speaker.
Conclusión
To install the new speaker, follow the instructions given in reverse.
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 24-30, Regan Fall 2012 Miembro de Cal Poly, Team 24-30, Regan Fall 2012
CPSU-REGAN-F12S24G30
5 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 8,632
