Introducción
If your device does not have power, replace the power input jack.
Herramientas
Partes
No se especificaron partes.
Use a Phillips #0 screwdriver to remove the four 21.7mm screws holding the back panel to the frame.
There will be two black wires connecting the top mounting bracket to the reverb box at the bottom of the unit. Label the wires to prevent crossing upon re-installation, then unplug the wires from the reverb box.
Before disconnecting the wires, label, make note of, or memorize each wire according to where it connects to the power input jack.
Disconnect the wire connectors from the back of the input jack by pulling them away from the jack.
Once the old power jack is removed, to install the replacement power jack, follow the guide in reverse.
