Saltar al contenido principal
Fender Frontman 15r Fuse Replacement
Qué necesitas
  1. Fender Frontman 15r Fuse Replacement, Fuse: paso 1, imagen 1 de 3 Fender Frontman 15r Fuse Replacement, Fuse: paso 1, imagen 2 de 3 Fender Frontman 15r Fuse Replacement, Fuse: paso 1, imagen 3 de 3
    • Be sure to unplug the device before proceeding.
    • Insert any tool with a small, flat end (such as a spudger, flathead screwdriver or plastic opening tool) into the groove in the bottom of the power input and wedge the plastic slot out from the amp.
    • There will be two compartments (one enclosed, one exposed) each containing a fuse. The exposed fuse is the active fuse and the enclosed one is a spare.
  2. Fender Frontman 15r Fuse Replacement: paso 2, imagen 1 de 2 Fender Frontman 15r Fuse Replacement: paso 2, imagen 2 de 2
    • Remove the blown exposed fuse and replace it with the enclosed fuse. If there is not an extra enclosed fuse, a new fuse must be ordered and inserted into the exposed slot.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 24-30, Regan Fall 2012 Miembro de Cal Poly, Team 24-30, Regan Fall 2012
CPSU-REGAN-F12S24G30
5 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 25
Todo El Tiempo: 13,910
