Saltar al contenido principal
Fender 65 Twin Reverb Preamp Tube Replacement
Qué necesitas
  1. Fender 65 Twin Reverb Preamp Tube Replacement, Preamp Tube: paso 1, imagen 1 de 3 Fender 65 Twin Reverb Preamp Tube Replacement, Preamp Tube: paso 1, imagen 2 de 3 Fender 65 Twin Reverb Preamp Tube Replacement, Preamp Tube: paso 1, imagen 3 de 3
    • Make sure to unplug the power cord!
    • Take off the back panel by unscrewing the four Phillips head screws on the back of the amplifier. You will find the six preamp tubes are the smaller ones on the right. (The picture only shows five of the six.)
    • Keep the screws in a safe place and mark what part they are for.
  2. Fender 65 Twin Reverb Preamp Tube Replacement: paso 2, imagen 1 de 2 Fender 65 Twin Reverb Preamp Tube Replacement: paso 2, imagen 2 de 2
    • Remove the metal casing by gently pressing up against the case and twisting to the right.
  3. Fender 65 Twin Reverb Preamp Tube Replacement: paso 3, imagen 1 de 2 Fender 65 Twin Reverb Preamp Tube Replacement: paso 3, imagen 2 de 2
    • Using the cloth, remove one tube by firmly grasping and gently pulling downwards.
    • Pulling directly downwards prevents damage to the hookup prongs at the bottom of the tube.
  4. Fender 65 Twin Reverb Preamp Tube Replacement: paso 4, imagen 1 de 1
    • Check the tube for any cracks in the glass. Also check to make sure the filaments are not burnt out.
    • If the tube is still functioning or to insert the replacement or, proceed to step five.
  5. Fender 65 Twin Reverb Preamp Tube Replacement: paso 5, imagen 1 de 2 Fender 65 Twin Reverb Preamp Tube Replacement: paso 5, imagen 2 de 2
    • Take the new replacement tube and insert it into the appropriate slot, making sure that the prongs at the end line up with the correct holes.
    • You should hear a click when the tube is secured in place.
    • Repeat these steps with the other three tubes if necessary.
Conclusión
2 personas más completaron esta guía.
Andrew Exton
Miembro Desde 01/26/14
141 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 9-27, Maness Winter 2014 Miembro de Cal Poly, Team 9-27, Maness Winter 2014
CPSU-MANESS-W14S9G27
Miembros de 5
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 30
Todo El Tiempo: 6,459
