Saltar al contenido principal
Fender '65 Tube Amp Speaker Replacement
Qué necesitas
  1. Fender '65 Tube Amp Speaker Replacement, Speaker: paso 1, imagen 1 de 1
    • Lay the amplifier face-down.
  2. Fender '65 Tube Amp Speaker Replacement: paso 2, imagen 1 de 1
    • Remove both back plates by unscrewing eight 1.2 mm screws with a Phillips #1 screwdriver.
    • Keep track of the eyelets.
  3. Fender '65 Tube Amp Speaker Replacement: paso 3, imagen 1 de 2 Fender '65 Tube Amp Speaker Replacement: paso 3, imagen 2 de 2
    • Remove the power stage vacuum tubes. Gently pull out the tube while simultaneously pressing down the metal holder.
  4. Fender '65 Tube Amp Speaker Replacement: paso 4, imagen 1 de 3 Fender '65 Tube Amp Speaker Replacement: paso 4, imagen 2 de 3 Fender '65 Tube Amp Speaker Replacement: paso 4, imagen 3 de 3
    • Remove the positive and negative speaker connections and label them accordingly with a marker and painter's tape.
  5. Fender '65 Tube Amp Speaker Replacement: paso 5, imagen 1 de 1
    • Remove the other side of the speaker connection from the internal speaker input jack.
  6. Fender '65 Tube Amp Speaker Replacement: paso 6, imagen 1 de 3 Fender '65 Tube Amp Speaker Replacement: paso 6, imagen 2 de 3 Fender '65 Tube Amp Speaker Replacement: paso 6, imagen 3 de 3
    • Remove the reverb tank by unscrewing two 1.2 mm screws with a Phillips #1 screwdriver and unfastening the velcro by hand.
    • The wire must stay connected.
  7. Fender '65 Tube Amp Speaker Replacement: paso 7, imagen 1 de 3 Fender '65 Tube Amp Speaker Replacement: paso 7, imagen 2 de 3 Fender '65 Tube Amp Speaker Replacement: paso 7, imagen 3 de 3
    • Remove the speaker by unscrewing four 1.2 mm screws with a Phillips #1 screwdriver.
    • Potential for device damage: Do not touch the front of the speaker when handling.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 60
