Saltar al contenido principal
Introducción
This guide shows how to replace the trigger assembly in the Fellowes T7CM.
Partes
No se especificaron partes.
  1. Fellowes T7CM Trigger Assembly Replacement, Fellowes T7CM Casing and Trigger Replacement: paso 1, imagen 1 de 1
    • Check to make sure the shredder is not plugged in to any electrical outlet.
    • Remove the shredder from the catch basket and place the silver side down on a flat surface.
    • Place the catch basket aside as you will not be needing it for the rest of the disassembly.
  2. Fellowes T7CM Trigger Assembly Replacement: paso 2, imagen 1 de 1
    • Flip the shredder silver side down and place on a flat even surface.
    • Remove the manufacturer's label in order to gain access to the hidden screw hole.
    • Locate all five of the case screws and remove them with a Phillips-Head screwdriver. The screws are located within the five marked circles in the photo. The size of the screws are 18 mm in length and head diameter of 5 mm.
  3. Fellowes T7CM Trigger Assembly Replacement: paso 3, imagen 1 de 1
    • Once all of the screws are removed, slowly pull apart the casing.
    • If the casing is not separating, gently wiggle the top part of the casing from the bottom part of the casing.
    • Use Caution during this procedure to prevent from damaging any of the internal parts.
  4. Fellowes T7CM Trigger Assembly Replacement: paso 4, imagen 1 de 1
    • Open the casing as shown to prevent tangling or damaging the wires.
    • Take note to how the trigger assembly is attached before removal.
    • The trigger assembly is one part and should come off all together with little to no force applied.
    • Remove the trigger assembly.
  5. Fellowes T7CM Trigger Assembly Replacement, Trigger Assembly: paso 5, imagen 1 de 1
    • Remove the trigger assembly by gently twisting and pushing it.
    • The assembly should come off easily with little effort.
Conclusión
Una persona más ha completado esta guía.
Michael Aldrich
Miembro Desde 12/10/16
686 Reputación
5 Guías creadas
Equipo
IUPUI, Team 2-2, Baechle Fall 2016 Miembro de IUPUI, Team 2-2, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G2
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 23
Todo El Tiempo: 1,443
