Saltar al contenido principal
Fellowes T7CM Shaft Replacement
Qué necesitas
  1. Fellowes T7CM Shaft Replacement, Fellowes T7CM Casing and Trigger Replacement: paso 1, imagen 1 de 1
    • Check to make sure the shredder is not plugged in to any electrical outlet.
    • Remove the shredder from the catch basket and place the silver side down on a flat surface.
    • Place the catch basket aside as you will not be needing it for the rest of the disassembly.
  2. Fellowes T7CM Shaft Replacement: paso 2, imagen 1 de 1
    • Flip the shredder silver side down and place on a flat even surface.
    • Remove the manufacturer's label in order to gain access to the hidden screw hole.
    • Locate all five of the case screws and remove them with a Phillips-Head screwdriver. The screws are located within the five marked circles in the photo. The size of the screws are 18 mm in length and head diameter of 5 mm.
  3. Fellowes T7CM Shaft Replacement: paso 3, imagen 1 de 1
    • Once all of the screws are removed, slowly pull apart the casing.
    • If the casing is not separating, gently wiggle the top part of the casing from the bottom part of the casing.
    • Use Caution during this procedure to prevent from damaging any of the internal parts.
  4. Fellowes T7CM Shaft Replacement: paso 4, imagen 1 de 1
    • Open the casing as shown to prevent tangling or damaging the wires.
    • Take note to how the trigger assembly is attached before removal.
    • The trigger assembly is one part and should come off all together with little to no force applied.
    • Remove the trigger assembly.
  5. Fellowes T7CM Shaft Replacement, Gear and Shaft: paso 5, imagen 1 de 2 Fellowes T7CM Shaft Replacement, Gear and Shaft: paso 5, imagen 2 de 2
    • Remove the three screws holding the internal case to the external case. The screw length is 18 mm and the head diameter is 5 mm.
    • Remove the internal case.
  6. Fellowes T7CM Shaft Replacement: paso 6, imagen 1 de 1
    • Remove the feeding sensor by unscrewing the single screw holding it. The screw length is 10 mm and the head diameter is 6 mm.
    • This step may be unnecessary, but it will prevent the sensor from being damaged.
  7. Fellowes T7CM Shaft Replacement: paso 7, imagen 1 de 2 Fellowes T7CM Shaft Replacement: paso 7, imagen 2 de 2
    • Remove the six screws on the gearbox.
    • Remove the gearbox cover to expose the gears.
    • The screw length is 34 mm and the head diameter is 7 mm.
    • The screw length is 26 mm and the head diameter is 7 mm.
  8. Fellowes T7CM Shaft Replacement: paso 8, imagen 1 de 3 Fellowes T7CM Shaft Replacement: paso 8, imagen 2 de 3 Fellowes T7CM Shaft Replacement: paso 8, imagen 3 de 3
    • Remove the gears.
    • The larger gear located in the middle may require a screwdriver to pry off.
    • Remove the gear holder by unscrewing two screws that are holding it in place. The screw length is 14 mm and the head diameter is 5 mm.
  9. Fellowes T7CM Shaft Replacement: paso 9, imagen 1 de 2 Fellowes T7CM Shaft Replacement: paso 9, imagen 2 de 2
    • Remove the pin in order to pull the casing off of the shafts.
    • Remove the casing in order to expose shafts.
  10. Fellowes T7CM Shaft Replacement, Shaft: paso 10, imagen 1 de 1
    • Remove the metal attachment that holds the two shafts together.
  11. Fellowes T7CM Shaft Replacement: paso 11, imagen 1 de 1
    • The shafts can now be pulled apart and any obstructions located between or on each of the shafts can be removed.
Conclusión
3 personas más completaron esta guía.
Michael Aldrich
Miembro Desde 10/12/16
686 Reputación
5 Guías creadas
Equipo
IUPUI, Team 2-2, Baechle Fall 2016 Miembro de IUPUI, Team 2-2, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G2
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 15
Todo El Tiempo: 1,113
