Saltar al contenido principal
Tonneau Trifold Bed Cover Retention Pin Replacement
Qué necesitas
  1. Tonneau Trifold Bed Cover Retention Pin Replacement, Retention Pin: paso 1, imagen 1 de 3 Tonneau Trifold Bed Cover Retention Pin Replacement, Retention Pin: paso 1, imagen 2 de 3 Tonneau Trifold Bed Cover Retention Pin Replacement, Retention Pin: paso 1, imagen 3 de 3
    • Locate the two screws on the retaining latch.
    • Use an Allen Wrench to loosen the screws.
    • The screws are tight and may require significant force.
  2. Tonneau Trifold Bed Cover Retention Pin Replacement: paso 2, imagen 1 de 2 Tonneau Trifold Bed Cover Retention Pin Replacement: paso 2, imagen 2 de 2
    • Continue loosening the screws until they are both loose enough to remove by hand.
  3. Tonneau Trifold Bed Cover Retention Pin Replacement: paso 3, imagen 1 de 3 Tonneau Trifold Bed Cover Retention Pin Replacement: paso 3, imagen 2 de 3 Tonneau Trifold Bed Cover Retention Pin Replacement: paso 3, imagen 3 de 3
    • Grab both screws and pull them straight out.
    • Line up the holes on the replacement latch, then insert the new screws.
  4. Tonneau Trifold Bed Cover Retention Pin Replacement: paso 4, imagen 1 de 3 Tonneau Trifold Bed Cover Retention Pin Replacement: paso 4, imagen 2 de 3 Tonneau Trifold Bed Cover Retention Pin Replacement: paso 4, imagen 3 de 3
    • Hand tighten both of the bolts onto the new latch.
  5. Tonneau Trifold Bed Cover Retention Pin Replacement: paso 5, imagen 1 de 2 Tonneau Trifold Bed Cover Retention Pin Replacement: paso 5, imagen 2 de 2
    • Tighten both screws evenly until the latch is held firmly in place.
    • Do not over tighten - you could break the Allen Wrench or strip the screws!
Conclusión
To reassemble your device, follow these instructions in order.
Christopher King
Miembro Desde 01/16/18
139 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 688
