Saltar al contenido principal
Fast Fix 2006 Honda CR-V Key Fob Buttons Replacement
Qué necesitas
  1. Fast Fix 2006 Honda CR-V Key Fob Buttons Replacement, 2006 Honda CR-V Key Fob: paso 1, imagen 1 de 1
    • You will need to take the key off the ring.
  2. Fast Fix 2006 Honda CR-V Key Fob Buttons Replacement: paso 2, imagen 1 de 1
    • The second step is to take out the little screw on the back side of the key.
  3. Fast Fix 2006 Honda CR-V Key Fob Buttons Replacement: paso 3, imagen 1 de 1
    • Unclip the back part of your key.
    • This part is super fragile.
  4. Fast Fix 2006 Honda CR-V Key Fob Buttons Replacement: paso 4, imagen 1 de 1
    • You will push the buttons from the front side to have the middle piece fall out.
  5. Fast Fix 2006 Honda CR-V Key Fob Buttons Replacement: paso 5, imagen 1 de 2 Fast Fix 2006 Honda CR-V Key Fob Buttons Replacement: paso 5, imagen 2 de 2
    • Then you will unclip the middle part. There is one clip on each side of this piece. They are super fragile and can break easily.
  6. Fast Fix 2006 Honda CR-V Key Fob Buttons Replacement: paso 6, imagen 1 de 2 Fast Fix 2006 Honda CR-V Key Fob Buttons Replacement: paso 6, imagen 2 de 2
    • Then push the buttons from the front side to push out a rubber insert.
  7. Fast Fix 2006 Honda CR-V Key Fob Buttons Replacement: paso 7, imagen 1 de 1
    • Then peel out the mother chip and replace your rubber insert.
Conclusión
2 personas más completaron esta guía.
2 comentarios
How do you remove the key from broken fob and put in new fob so you don’t have to incur the cost of cutting new key?
Me Me - Contestar
Just open the fob, like in this tutorial. The key is just a piece of metal.
Then place the key in a new fob (or replace only the fob plastic case for a cheaper solution).
Brendan -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 51
Todo El Tiempo: 2,318
