Saltar al contenido principal
Farberware FSTO100 Power Supply Replacement
Qué necesitas
  1. Farberware FSTO100 Power Supply Replacement, Power Supply: paso 1, imagen 1 de 1
    • Make sure the toaster is unplugged.
    • First, to remove the plastic bracket, turn toaster oven on its side.
  2. Farberware FSTO100 Power Supply Replacement: paso 2, imagen 1 de 1
    • Use Phillips head screwdriver and wrench to remove screw and nut securing the plastic bracket.
  3. Farberware FSTO100 Power Supply Replacement: paso 3, imagen 1 de 1
    • Use Phillips head screwdriver and pliers to remove screw and nut securing transformer.
  4. Farberware FSTO100 Power Supply Replacement: paso 4, imagen 1 de 1
    • If the wire gets pulled out of the transformer, reinsert it.
    • Use a small flathead screwdriver to secure the screw that holds the wire in place.
Conclusión
Tony Wang
Miembro Desde 10/05/12
103 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 6-35, Regan Fall 2012 Miembro de Cal Poly, Team 6-35, Regan Fall 2012
CPSU-REGAN-F12S6G35
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 13
Todo El Tiempo: 1,413
