Saltar al contenido principal
Farberware FSTO100 Indicator Light Replacement
Qué necesitas
  1. Farberware FSTO100 Indicator Light Replacement, Indicator Light: paso 1, imagen 1 de 1
    • Make sure toaster is unplugged.
    • Turn toaster upside down so screws on bottom side are facing toward the ceiling and the door is facing towards you.
  2. Farberware FSTO100 Indicator Light Replacement: paso 2, imagen 1 de 1
    • On the left hand side, unscrew the middle screw.
  3. Farberware FSTO100 Indicator Light Replacement: paso 3, imagen 1 de 1
    • Remove the panel on the left hand side. The indicator light is located in the red tube that has wires covered by black tubing coming out.
  4. Farberware FSTO100 Indicator Light Replacement: paso 4, imagen 1 de 1
    • Pull the black wires to remove the indicator light from the red tube.
  5. Farberware FSTO100 Indicator Light Replacement: paso 5, imagen 1 de 2 Farberware FSTO100 Indicator Light Replacement: paso 5, imagen 2 de 2
    • Use scissors to cut open cord sheathing and peel back.
  6. Farberware FSTO100 Indicator Light Replacement: paso 6, imagen 1 de 1
    • Use the wire-cutters to remove the light bulb.
  7. Farberware FSTO100 Indicator Light Replacement: paso 7, imagen 1 de 2 Farberware FSTO100 Indicator Light Replacement: paso 7, imagen 2 de 2
    • Solder the replacement light bulb back onto its original position.
  8. Farberware FSTO100 Indicator Light Replacement: paso 8, imagen 1 de 1
    • Use electrical tape to reseal the sheathing.
  9. Farberware FSTO100 Indicator Light Replacement: paso 9, imagen 1 de 1
    • Reinsert the indicator light back into the red tube.
  10. Farberware FSTO100 Indicator Light Replacement: paso 10, imagen 1 de 1
  11. Farberware FSTO100 Indicator Light Replacement: paso 11, imagen 1 de 1
    • On the left hand side, screw the middle screw back in.
Conclusión
Una persona más ha completado esta guía.
Tony Wang
Miembro Desde 10/05/12
103 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 6-35, Regan Fall 2012 Miembro de Cal Poly, Team 6-35, Regan Fall 2012
CPSU-REGAN-F12S6G35
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 9
Ultimos 30 días: 10
Todo El Tiempo: 850
