Saltar al contenido principal
Fairphone SIM Card Replacement
  1. Fairphone SIM Card Replacement, Back Cover: paso 1, imagen 1 de 3 Fairphone SIM Card Replacement, Back Cover: paso 1, imagen 2 de 3 Fairphone SIM Card Replacement, Back Cover: paso 1, imagen 3 de 3
    • There is a small indentation in the side of the phone near the bottom of the back cover.
    • With the indentation as leverage, use your fingernail to pry the bottom portion of the back cover from the phone.
  2. Fairphone SIM Card Replacement: paso 2, imagen 1 de 3 Fairphone SIM Card Replacement: paso 2, imagen 2 de 3 Fairphone SIM Card Replacement: paso 2, imagen 3 de 3
    • Slide the back cover down and remove it from the phone.
  3. Fairphone SIM Card Replacement, Battery: paso 3, imagen 1 de 3 Fairphone SIM Card Replacement, Battery: paso 3, imagen 2 de 3 Fairphone SIM Card Replacement, Battery: paso 3, imagen 3 de 3
    • There is a small indentation in the back of the phone just below the battery.
    • Use a fingernail in this indentation to push the battery toward the top of the phone
    • Pull the battery out away from the phone.
  4. Fairphone SIM Card Replacement: paso 4, imagen 1 de 1
    • Remove the battery from your Fairphone.
  5. Fairphone SIM Card Replacement, SIM and MicroSD Card: paso 5, imagen 1 de 3 Fairphone SIM Card Replacement, SIM and MicroSD Card: paso 5, imagen 2 de 3 Fairphone SIM Card Replacement, SIM and MicroSD Card: paso 5, imagen 3 de 3
    • Use your finger to slide the SIM card straight down out of its tray.
    • Remove the SIM card from your Fairphone.
    • Repeat this procedure if you have a second SIM card.
    • Be sure to remove all SIM cards before servicing your phone.
  6. Fairphone SIM Card Replacement: paso 6, imagen 1 de 2 Fairphone SIM Card Replacement: paso 6, imagen 2 de 2
    • If you have a microSD card, use your finger to slide it straight out of its slot.
    • Remove the microSD card from your phone.
Conclusión
Una persona más ha completado esta guía.
Sam Goldheart
Miembro Desde 10/18/12
457,252 Reputación
537 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
137 Miembros
17,047 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 38
Ultimos 30 días: 152
Todo El Tiempo: 6,416
