Saltar al contenido principal
Fairphone 2 Microphone Module Replacement
Qué necesitas
  1. Fairphone 2 Microphone Module Replacement, Slim Case: paso 1, imagen 1 de 3 Fairphone 2 Microphone Module Replacement, Slim Case: paso 1, imagen 2 de 3 Fairphone 2 Microphone Module Replacement, Slim Case: paso 1, imagen 3 de 3
    • Pick a corner of your slim case and get between the two parts with your thumb's fingernails.
    • Pull up the back part of the slim case to separate the small snap fit connections.
    • Remove the back part of the slim case.
  2. Fairphone 2 Microphone Module Replacement: paso 2, imagen 1 de 3 Fairphone 2 Microphone Module Replacement: paso 2, imagen 2 de 3 Fairphone 2 Microphone Module Replacement: paso 2, imagen 3 de 3
    • Get in between the front part of the slim case and the phone's body with your thumb nail.
    • Separate the snap fit connectors on the front part by pulling it to the side and pushing against the display.
  3. Fairphone 2 Microphone Module Replacement: paso 3, imagen 1 de 1
    • Remove the front part of the slim case.
  4. Fairphone 2 Microphone Module Replacement, Battery: paso 4, imagen 1 de 3 Fairphone 2 Microphone Module Replacement, Battery: paso 4, imagen 2 de 3 Fairphone 2 Microphone Module Replacement, Battery: paso 4, imagen 3 de 3
    • Push the battery toward the top of the phone.
    • Pull the battery out away from the phone.
  5. Fairphone 2 Microphone Module Replacement, Display Assembly: paso 5, imagen 1 de 3 Fairphone 2 Microphone Module Replacement, Display Assembly: paso 5, imagen 2 de 3 Fairphone 2 Microphone Module Replacement, Display Assembly: paso 5, imagen 3 de 3
    • After taking out the battery you can unlock the display assembly.
    • Flip the two blue switches to the inner position.
    • Slide the display assembly towards the bottom of the phone.
    • Another possible way of sliding the display assembly open.
  6. Fairphone 2 Microphone Module Replacement: paso 7, imagen 1 de 1
    • Take off the display assembly.
  7. Fairphone 2 Microphone Module Replacement, Microphone Module: paso 8, imagen 1 de 1
    • Remove the four Phillips #0 screws that are factory-marked with blue circles.
  8. Fairphone 2 Microphone Module Replacement: paso 9, imagen 1 de 1
    • Take out the whole microphone module.
Conclusión
Information on what to do with the old module can be found on the FairPhone support page and in the FairPhone forum.
107 personas más completaron esta guía.
Tobias Isakeit
Miembro Desde 03/31/14
117,597 Reputación
188 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
322 Miembros
2,532 Guías creadas
38 comentarios
Bonjour,
j'ai aussi galéré de peur de casser quelque chose, mais j'ai trouvé une solution sur le forum anglais de Fairphone:
https://forum.fairphone.com/t/fp2-teardo...
j'espère que ça t'aidera (faut oser un petit peu, voir comment ça glisse et faire un peu jouer tout ça... ça m'a pris 3/4 d'heure avant d'y arriver... sans rien endommager :) )
pacpacbouroucouta - Contestar
Just a little comment. I have seen many times the so called primary microphone error of the fairphone2 on the internet. I had the problem but it had nothing to do with the microphone but with the electric connection/module to the display module. If you have this problem you can check whether the mic works fine if you press tightly together the phone around the microphone module (just call another phone and try it). If this helps, there is a good chance that the true reason are worn out plastic parts around. I fixed it by putting a millimeter of tape underneath the microphone module and before screwing it on again. Now the module gets pressed a little bit against the display module and works just fine again (for the moment). Probably the little worn out outer shell was a part of the problem, I did not have a new one, but could imagine that buying a new outer shell for the fairphone2 might rather solve the problem than changing the microphone module. Just try it yourself before ordering a new microphone.
mietzekiss - Contestar
Thanks! That did the trick.
Célestin Taramarcaz -
Thanks! Worked for me too after trying out different thicknesses (by adding and removing layers of tape). As well as adding tape on the inside of the microphone module (on long side of inverse 'L' shape) I added a little on the inside of the case itself (case is also breaking).
On a side note, love the ability to open up and adjust my phone!
Eve Williams -
The "millimeter tape fix" has been working fine for about a week, but now I'm back to square one: still no sound at the other end. I ordered a new hard cover but still to no avail... And Fairphone is still out of microphone modules. I'm out of options, I guess I'll just send my FP2 for repair, hoping it won't take too long.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 15
Ultimos 30 días: 42
Todo El Tiempo: 126,848
