Saltar al contenido principal
Fahrenheit FHT 125PRMR Motherboard Replacement
Qué necesitas
  1. Fahrenheit FHT 125PRMR Motherboard Replacement, Motherboard: paso 1, imagen 1 de 1
    • Remove both hinge covers on each side of the flat iron.
  2. Fahrenheit FHT 125PRMR Motherboard Replacement: paso 2, imagen 1 de 1
    • Using Philips head #2 remove the 7 mm black screw that was underneath one of the hinge covers.
  3. Fahrenheit FHT 125PRMR Motherboard Replacement: paso 3, imagen 1 de 2 Fahrenheit FHT 125PRMR Motherboard Replacement: paso 3, imagen 2 de 2
    • Using the metal spudger, push through the hole the screw was removed from. Doing this will push the copper pin out of the other side.
    • When the pin is removed the two sides of the device can now separate.
    • Be sure to collect the spring that is next to the hinge when they are separated.
  4. Fahrenheit FHT 125PRMR Motherboard Replacement: paso 4, imagen 1 de 2 Fahrenheit FHT 125PRMR Motherboard Replacement: paso 4, imagen 2 de 2
    • Using Philips head #1 remove the 6 mm black screw that was underneath the spring as well as the 6 mm black screw next to the heating plate. Remove the panel the screws were holding down.
  5. Fahrenheit FHT 125PRMR Motherboard Replacement: paso 5, imagen 1 de 1
    • Using Philips head #1 remove the two 4 mm silver screws on the sides of dial panel cover.
  6. Fahrenheit FHT 125PRMR Motherboard Replacement: paso 6, imagen 1 de 2 Fahrenheit FHT 125PRMR Motherboard Replacement: paso 6, imagen 2 de 2
    • Using Philips head #00 to remove the 4 mm silver screw on the dial. Remove the dial with your hand.
  7. Fahrenheit FHT 125PRMR Motherboard Replacement: paso 7, imagen 1 de 1
    • Remove the covering panel by pulling up with your hand.
  8. Fahrenheit FHT 125PRMR Motherboard Replacement: paso 8, imagen 1 de 2 Fahrenheit FHT 125PRMR Motherboard Replacement: paso 8, imagen 2 de 2
    • Remove three 3 mm sliver screws #1 from the motherboard.
    • Use your hand to life the motherboard out of the flat iron.
  9. Fahrenheit FHT 125PRMR Motherboard Replacement: paso 9, imagen 1 de 1
Conclusión
MeKenzie Hilsmeyer
Miembro Desde 09/29/16
23 Reputación
1 Guía escrita
Equipo
IUPUI, Team 2-2, Harley Fall 2016 Miembro de IUPUI, Team 2-2, Harley Fall 2016
IUPUI-HARLEY-F16S2G2
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 1,566
