Saltar al contenido principal
Fahrenheit FHT 125PRMR Dial Replacement
Qué necesitas
  1. Fahrenheit FHT 125PRMR Dial Replacement, Dial: paso 1, imagen 1 de 1
    • Use your fingers or a plastic opening tool to open the side hinges on both sides of the device.
  2. Fahrenheit FHT 125PRMR Dial Replacement: paso 2, imagen 1 de 1
    • Using a Philips head #2 screwdriver remove the 7mm black screw from the hinge of the device.
  3. Fahrenheit FHT 125PRMR Dial Replacement: paso 3, imagen 1 de 2 Fahrenheit FHT 125PRMR Dial Replacement: paso 3, imagen 2 de 2
    • Using the metal spudger, push through the hole the screw was removed from. Doing this will push the copper pin out of the other side.
    • When the pin is removed the two sides of the device can now separate.
    • Be sure to collect the spring that is next to the hinge when they are separated.
  4. Fahrenheit FHT 125PRMR Dial Replacement: paso 4, imagen 1 de 2 Fahrenheit FHT 125PRMR Dial Replacement: paso 4, imagen 2 de 2
    • Using a Philips head #1 screwdriver remove the two 6mm black screws on both sides of the dial panel cover.
  5. Fahrenheit FHT 125PRMR Dial Replacement: paso 5, imagen 1 de 1
    • Using a Philips head #1 screwdriver remove the two 4mm silver screws on both sides of the dial panel cover.
  6. Fahrenheit FHT 125PRMR Dial Replacement: paso 6, imagen 1 de 2 Fahrenheit FHT 125PRMR Dial Replacement: paso 6, imagen 2 de 2
    • Using a Philips head #00 screwdriver remove the 4mm silver screw from the center of the dial.
    • Remove the dial after the screw is removed with either your hand or a plastic opening tool.
  7. Fahrenheit FHT 125PRMR Dial Replacement: paso 7, imagen 1 de 1
    • Remove the covering panel by pulling up with your hand.
  8. Fahrenheit FHT 125PRMR Dial Replacement: paso 8, imagen 1 de 1
Conclusión
Nicolas Moreau
Miembro Desde 09/29/16
180 Reputación
1 Guía escrita
Equipo
IUPUI, Team 2-2, Harley Fall 2016 Miembro de IUPUI, Team 2-2, Harley Fall 2016
IUPUI-HARLEY-F16S2G2
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 26
Todo El Tiempo: 813
