Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
FS-200 Impulse Heat Sealer Heating Element Replacement
Qué necesitas
  1. FS-200 Impulse Heat Sealer Heating Element Replacement, Heating Element: paso 1, imagen 1 de 2 FS-200 Impulse Heat Sealer Heating Element Replacement, Heating Element: paso 1, imagen 2 de 2
    • Unplug the heat sealer from any power source and make sure the heat sealer isn't hot.
    • Lift the sealing arm and position it up and out of the way to create space for the replacement.
  2. FS-200 Impulse Heat Sealer Heating Element Replacement: paso 2, imagen 1 de 3 FS-200 Impulse Heat Sealer Heating Element Replacement: paso 2, imagen 2 de 3 FS-200 Impulse Heat Sealer Heating Element Replacement: paso 2, imagen 3 de 3
    • Using a standard Phillips #2 screwdriver, remove the first two screws to detach the first metal panel.
  3. FS-200 Impulse Heat Sealer Heating Element Replacement: paso 3, imagen 1 de 2 FS-200 Impulse Heat Sealer Heating Element Replacement: paso 3, imagen 2 de 2
    • Using a standard Phillips #2 screwdriver, unscrew the remaining two screws to remove the second metal panel.
  4. FS-200 Impulse Heat Sealer Heating Element Replacement: paso 4, imagen 1 de 2 FS-200 Impulse Heat Sealer Heating Element Replacement: paso 4, imagen 2 de 2
    • Remove the teflon strip to expose the heating element wire.
  5. FS-200 Impulse Heat Sealer Heating Element Replacement: paso 5, imagen 1 de 3 FS-200 Impulse Heat Sealer Heating Element Replacement: paso 5, imagen 2 de 3 FS-200 Impulse Heat Sealer Heating Element Replacement: paso 5, imagen 3 de 3
    • Using a standard Phillips #2 screwdriver, unscrew the large single screw and remove the old heating element wire.
  6. FS-200 Impulse Heat Sealer Heating Element Replacement: paso 6, imagen 1 de 3 FS-200 Impulse Heat Sealer Heating Element Replacement: paso 6, imagen 2 de 3 FS-200 Impulse Heat Sealer Heating Element Replacement: paso 6, imagen 3 de 3
    • Position the new heating element by placing one end of the wire onto the pin located beneath the arm lever.
  7. FS-200 Impulse Heat Sealer Heating Element Replacement: paso 7, imagen 1 de 1
    • Stretch the wire across the base pulling it towards the corresponding screw hole. The pin from the first side will slide as you pull it tight.
    • Holding the heating element taught, line up the 2 holes and use a standard Phillips #2 screwdriver to screw in the large single screw.
Conclusión
AshleyDrake
Miembro Desde 01/21/25
145 Reputación
1 Guía escrita
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 42
Todo El Tiempo: 206
