Saltar al contenido principal
FIAT 500 Low Beam Bulb Replacement
Qué necesitas
  1. FIAT 500 Low Beam Bulb Replacement, Low Beam Bulb: paso 1, imagen 1 de 3 FIAT 500 Low Beam Bulb Replacement, Low Beam Bulb: paso 1, imagen 2 de 3 FIAT 500 Low Beam Bulb Replacement, Low Beam Bulb: paso 1, imagen 3 de 3
    • Apply the handbrake and remove the keys, then open the hood.
  2. FIAT 500 Low Beam Bulb Replacement: paso 2, imagen 1 de 2 FIAT 500 Low Beam Bulb Replacement: paso 2, imagen 2 de 2
    • Remove the cover by pulling on the tip.
    • The cover is easy to remove, but take a good look at how it is secured so it can be reinstalled in the same orientation
  3. FIAT 500 Low Beam Bulb Replacement: paso 3, imagen 1 de 3 FIAT 500 Low Beam Bulb Replacement: paso 3, imagen 2 de 3 FIAT 500 Low Beam Bulb Replacement: paso 3, imagen 3 de 3
    • Pinch and hold the bulb holder by its release tab and remove the holder and bulb from its housing.
    • Do this slowly; during reassembly you will have to put it back in the same position correctly.
    • While it's not important for a bulb you're going to dispose of, for new bulbs or a bulb you're going to reuse do not touch the glass with your bare hands. Oil from your skin can collect heat and result in failure of the glass envelope. If you do touch it by accident, clean it thoroughly with isopropyl alcohol.
  4. FIAT 500 Low Beam Bulb Replacement: paso 4, imagen 1 de 2 FIAT 500 Low Beam Bulb Replacement: paso 4, imagen 2 de 2
    • Hold the plastic bulb holder with one hand and remove the bulb by grasping it by the metal edges. Rock it back and forth to remove it.
  5. FIAT 500 Low Beam Bulb Replacement: paso 5, imagen 1 de 1
    • Replace the defective bulb with the same model, here H7 12V 55W.
Conclusión
To reassemble your headlight, follow the instructions in reverse order.
3 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
fr en
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
huby
Miembro Desde 08/19/21
1,560 Reputación
1 Guía escrita
2 comentarios
Bonsoir.......pourquoi toujours montrer le remplacement sur le phare droit? Juste pour rire, remplacer l'ampoule de code sur le phare gauche avec la traverse, la batterie et la boîte a fusible..........j'ai dû le faire et je vous promet que j'aurai mis avec un immense plaisir, des grandes claques dans la gueule des ingénieurs ! Il faut avoir une main d'un enfant de 5ans avec des doigts de pianiste avec une dextérité de gynéco et une patiente d'ange. Curieux de voir un tuto "facile".
Frederic Guy - Contestar
C'est pas faux ! 😂
R B - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 19
Ultimos 7 días: 107
Ultimos 30 días: 575
Todo El Tiempo: 14,791
