Saltar al contenido principal
FDHD Floppy drive Disassembly
Qué necesitas
  1. FDHD Floppy drive Disassembly, Step 1 pull off the springs: paso 1, imagen 1 de 1
    • It’s best to pull Down and twist to pull the spring off
  2. FDHD Floppy drive Disassembly, Pull the other spring off: paso 2, imagen 1 de 1
    • Once again pull and twist movement
  3. FDHD Floppy drive Disassembly, Move this black tab off: paso 3, imagen 1 de 1
    • lift up on the really tiny tab with a flat blade screwdriver and slide it off
    • Push Down
    • It may seem a little bit tricky at first but only push the ejection lever about halfway in
  4. FDHD Floppy drive Disassembly, Unscrew motor: paso 6, imagen 1 de 1
    • Remove these two screws and lift off the motor
    • Note: I did not have the second screw.
  5. FDHD Floppy drive Disassembly, Lift off motor: paso 7, imagen 1 de 1
    • Unplug the motors 3-pin connector to make it easier
  6. FDHD Floppy drive Disassembly, Take off the tiny black washers: paso 8, imagen 1 de 1
    • Insert wisdom here.
    • Thank you for using my guide just clean any places where metal touches metal and reassemble
Conclusión
Una persona más ha completado esta guía.
Thomas
Miembro Desde 05/14/23
433 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 76
